Activity › Forums › Apple Final Cut Pro › Seeing the length of a clip
  • Seeing the length of a clip
    Posted by Dennis Widmyer on November 25, 2013 at 7:34 pm
    Here’s a simple question:
    It seems that sometimes, I’m able to select any clip on my timeline, and Final Cut will show me the length of the selected clip at the very bottom of the screen. (on the grey strip at the bottom of the whole interface). Yet, just as often, the selected clip duration doesn’t show up there when I select a clip– instead, it just shows the entire length of the timeline.
    How do I get it to just show me the clip duration?
    Thank you.
    Dennis Widmyer
    http://www.parallacticpictures.com
    Tj Ingrassia replied 12 years, 9 months ago 6 Members · 13 Replies
  • 13 Replies
  • Jeremy Garchow
    November 25, 2013 at 7:46 pm
    I use this feature all the time and have never seen what you are explaining if something is selected.
    A range has to be selected in order for the selection duration to show up.
    If nothing is selected, then nothing shows up.
  • Dennis Widmyer
    November 25, 2013 at 7:51 pm
    Something is Off then. Right now, as I’m typing this to you, I have an entire clip selected/ It’s highlighted yellow. And at the bottom of the screen, all it’s showing me is the total duration of my entire film (timeline). Not the selected clip. Yet ten mins from now, while editing, this feature will randomly start working again. There’s gotta be something I’m not doing right here.
    Dennis Widmyer
  • Jeremy Garchow
    November 25, 2013 at 7:57 pm
    If possible, can you show a screengrab?
  • Michael Garber
    November 25, 2013 at 8:05 pm
    If you hover over the clip and hit X then you’ll select the clip range per Jeremy’s suggestion. Does that sore the duration?
    Michael Garber
    5th Wall – a post production company
    Blog: GARBERSHOP
    My Moviola Webinar on Cutting News in FCP X
  • Dennis Widmyer
    November 25, 2013 at 8:49 pm
    Thanks, guys. Both of these tricks worked perfectly. You saved me a lot of headache going forward.
    Dennis Widmyer
  • Bret Williams
    November 26, 2013 at 7:30 am
    BTW you’re not crazy. I saw this behavior recently. Reboot fixed it. Clicking on a clip in the timeline does give the duration when the app is functioning correctly.
  • Dennis Widmyer
    November 26, 2013 at 5:35 pm
    Yeah, figured it must be a bug. Because it’s very random and follows no pattern.
    Another bug I can’t stand, is when you fade to black on a clip, using the Opacity tool. Then you decide to undo it, and raise the Opacity back up to 100%, but ONE frame remains black, no matter what you do. The only way I’ve found to fix it, is to cut that frame out by lifting it, then go into ‘P’ mode and drag a frame over to where it was. Weird.
    Dennis Widmyer
  • Bret Williams
    November 26, 2013 at 6:03 pm
    Wow that is a bug. I was able to easily recreate. Once I figured out what the opacity tool was. I’ve never used it. It’s buried a bit deep. Why not simply use a cross dissolve?
    I was able to fix it by slicing off that frame, then simply extending the resulting video one frame. No P tool. Cmd+B, then click on the end and press >.
  • Dennis Widmyer
    November 26, 2013 at 10:10 pm
    Hi Bret,
    I’m actually not running into this bug b/c I want to create a cross dissolve. Rather, I want the scene to fade to total black. Then have the next scene start by fading up from that black. And as far as I know, the easiest way to do and have control over that, is to click Control V on the clip, bring up the Video options, and fade out the opacity.
    Dennis Widmyer
  • Bret Williams
    November 26, 2013 at 11:37 pm
    A dissolve to nothing is a fade to black. You could also use a fade to color effect between 2 clips. The color being black of course.
