Activity Forums Compression Techniques See GOP Frame By Frame and Data Rate over time for an encode
  • See GOP Frame By Frame and Data Rate over time for an encode
    Posted by Craig Seeman on October 28, 2015 at 7:49 pm
    As a compressionist I’ve been wanting to examine GOP frame by frame and data rate variance over time to trouble shoot encoding. I can finally do it in Switch Pro 2.0.
    GOP of a file Frame By Frame including individual I, P, B Frames
    Data Rate over time
    Eric Strand replied 10 years, 10 months ago 2 Members · 3 Replies
  • Eric Strand
    November 17, 2015 at 3:40 pm
    Hi Craig, that is cool to see. As a young compressionist/DIT, what is an example of a situation that you’ve been able to use this analysis?
    @ericstrand11
  • Craig Seeman
    November 17, 2015 at 4:35 pm
    Generally it’s a great troubleshooting assistant
    How variable is a CBR encode since that can cause issue where CBR is required.
    How wide are the data rate swings in a VBR encode in case the peaks might be causing issues.
    Is it hitting or under/over shooting minimum and maximum bit rate encoder settings
    How do the key frames impact the P and the B frames so one might see if anything is bit starved in a trouble area.
    When using Forced and Natural Key frames, where the Natural key frames are actually occurring.
    Comparing the same settings in two encoders to see if how much the results actually differ.
  • Eric Strand
    November 17, 2015 at 5:14 pm
    Ah, I see now, certainly makes sense. Thanks for the info.
    @ericstrand11
