Activity Forums VEGAS Pro See full composite in pan crop window while masking?
  • See full composite in pan crop window while masking?
    Posted by Franz Vorenkamp on October 12, 2008 at 8:08 am
    Hey guys.
    I’ve been using Sony Vegas Pro for a few years now- I like to think that I’ve got the whole thing figured out, but there’s one thing that’s been eluding me from the get-go… How to mask effectively in Vegas.
    To me, it seems like there should be some way to see the full composite, or atleast the layer below the clip you’re attempting to mask. Let me explain.
    I’ve got a TIF sequence with an alpha layer on layer one of the timeline, and directly below it is video footage of a window. I’d like to make it so that the flame is only visible on the glass sections of the window, and it seems like the easiest way to do this would be a mask in the pan/crop window.
    However, when you go into masking mode within the pan/crop, you only get the checkered background. It would be so much easier if you could just see the image directly under the object you’re attempting to mask- otherwise it’s just kind of shooting in the dark.
    Any suggestions?
    – FMV
    Franz Vorenkamp replied 17 years, 10 months ago 2 Members · 2 Replies
  • John Rofrano
    October 12, 2008 at 1:29 pm
    You could make the mask on the lower track where you can see the glass sections of the window and then cut and paste those keyframes into the flame track. You could also render to new track and make the keyframes there and then cut and paste back to the flame track.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Franz Vorenkamp
    October 12, 2008 at 5:50 pm
    Yeah, that’s more or less the solution I had in mind- I was just wondering if there was some simple thing I was missing.
