security camera footage mp4 won’t open
Posted by Larry Brewer on October 29, 2018 at 3:55 pmI have a thumbdrive with mp4 footage from a home security camera.
This footage plays fine in VLC, PotPlayer, but not WMP, or Quicktime.
And it won’t open in Vegas for editing.
Anyone with any suggestions?Francois Pénzes replied 7 years, 11 months ago 2 Members · 5 Replies -
Francois Pénzes
October 29, 2018 at 6:11 pmHi Larry
Have you tried converting it with Handbrake ?
Cheers ! (Keep us posted)
PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
Cameras: Canon XF305 + Canon XH-A1
Blackmagic HyperDeck Studio Mini
Vegas Pro 14, User since Vegas 3.0\’\’When the cutting stops, the editing begins…\’\’
Larry Brewer
October 29, 2018 at 8:35 pmYes, that was the first thing I tried after it wouldn’t open in Vegas 15, then Vegas 12. I have also tried multiple PCs and Adobe Premier on different desktops. Again.. it plays just fine in PotPlayer and VLC. But not WMP or Quicktime Player.
Apparently, there are proprietary codecs used in the CCTV industry. -
Francois Pénzes
October 30, 2018 at 1:14 amHi Larry
Can you do a Mediainfo on your problem file
https://sourceforge.net/projects/mediainfo/
Cheers !
Larry Brewer
October 30, 2018 at 1:30 amI found a work around using VLC. As I had mentioned VLC was one of the players that would play the clips. So I used it to do a convert back to MP4 at 5mbs and that imported just fine. Thanks you for your help and suggestions. Much appreciated.
Larry Brewer
Francois Pénzes
October 30, 2018 at 8:44 pmHi Larry
Happy to ear that you solved your problem. Just keep in mind that sometimes VLC files will create problems within Vegas. All depends how critical your project is if ever it starts acting up.
Cheers !
