Activity Forums Maxon Cinema 4D Sections =ll=
  • Sections =ll=
    Posted by Bryan Richards on February 28, 2006 at 2:56 am
    Ok guys,
    Ive been having fun with my new Maxon Form Toy, works a treat at creating much more sophisticated GDL objects for Archicad. ok less chit chat
    I want to cut through my architectural model
    H . O . W . ?
    cannot find a nice simple section tool.
    Boolean does not work with imported objects from Archicad where all of my modelling has been done (u know what i mean) so i cannot create a huge slab and subtract one side
    ANY CLUES?? thanks!!!
    Bryan Richards
    Bryan Richards replied 20 years, 6 months ago 3 Members · 4 Replies
  • Doug Bassett
    February 28, 2006 at 2:52 pm
    I would knife down the center from the top view.
    But since you seem to be wanting boolean, duplicate your object and use a cube boolean on one half and a cube boolean on the other.
    Then if you make the booleans editable you can select the parts and connect them into one (half) object from the objects menu.
  • Bryan Richards
    March 1, 2006 at 5:49 pm
    If only it was that simple
    Because im using an archicad export plug in the objects dont behave in exactly the same way. You cannot edit them for a start. To make an object editable you need to import to maxon form, create, edit, import back into Archicad , then into Cinema for rendering :S
    boolean does not work as i mentioned
    knife only works with editable cinema shapes
    My walls and windows for example have their own Archicad tag. Is there still a way of creating a section through the buildings??
  • Adam Trachtenberg
    March 2, 2006 at 4:08 am
    The only thing I can think of in your case is camera clipping (available in the camera>object menu), but that only clips the scene parallel to the film plane.
  • Bryan Richards
    March 9, 2006 at 5:31 am
    Best solution i found was
    1. use the Graphisoft cutting plane tool.
    2. define a new cutting section material
    3. Save you current C4d model as not to loose any of your modelling which was not done in Archicad
    4. Merge files importing materials only – this will automatically cut away the bit u do not need. Your full model is safe dont forget
    5. Define a contrasting cutting plane material in C4d (bright red)
    6. Render away.. it gives you a very readable rendered section.
