Activity Forums Apple Final Cut Pro Legacy Secret behind Rendering
  • Secret behind Rendering
    Posted by Jon Boffa on February 10, 2006 at 6:29 am
    Ive been using FCP for a few months now and I must ask: is there any way to get around having to constantly keep rendering changes on my timeline? Is there a setting that will automatically render any items that require it? Having to keep selecting the menu option gets to be a pain after a while…
    Any input would be much appreciative!
    JB
    Shane Ross replied 20 years, 6 months ago 2 Members · 1 Reply
  • Shane Ross
    February 10, 2006 at 6:48 am
    First off, your media settings should match your sequence settings so that when you add a clip to the timeline it doesn’t require rendering. Is that an issue? Or is it an issue with adding transitions?
    I have the RENDER menu option mapped to a key, so when I add a transition or effect that isn’t realtime, I press one button and it renders. You can do this with the CUSTOM KEYBOARD options. And use RENDER ALL: BOTH.
    Shane
    Alokut Productions
    http://www.lfhd.net
