Activity Forums Boris FX Particle Illusion Second/Home Network Computer = Faster PI?
  • Second/Home Network Computer = Faster PI?
    Posted by Philip Knight on November 25, 2009 at 10:01 pm
    I’ve toyed with this idea for a bit but don’t know enough about it.
    The basic question is:
    A — Can one substantially lighten the load on PI (and/or an NLE) by hooking up another computer as extra CPU muscle?
    B — If so, how and – what would be the most affordable way to go?
    This is kind of a segue from previous issue of slow FPS due to background videos in PI. So the prequel question to even considering this idea would be:
    Would such a setup actually help improve this situation or not?
    My current one stand-alone system specs are:
    – XP Home 32 bit
    – Pentium D 2.8 Ghz
    – As much RAM as 32 bit allows < 4 Gb.) - Multiple 7200 rpm SATA2 drives Thanks.
    Rob Holmes replied 14 years, 10 months ago 3 Members · 4 Replies
  • Alan Lorence
    November 29, 2009 at 2:15 pm
    No. There’s no distributed rendering in pIllusion.
    Alan.
    http://www.wondertouch.com
  • Rob Holmes
    October 30, 2011 at 12:27 am
    But is there Network Rendering? You say no “Distributed Rendering.” I can’t get PI to work with my AE 5.0 Render Queue Jobs sent to my farm machines. I get blank frames. I’ve run the installation on my farm machines and it appeared to go just fine. I tried to activate those nodes but nothing happened. I tried to Manually Activate those Hosts on the Activation Site and it said it couldn’t find the Activation Code.
    How do I set that up please? I guess I should have asked that question before I purchased the app last night to finish up a job.
    Asus P5K-Deluxe – Intel Core2 Extreme QX6850 – 8GB DDR2 1066Mhz -ATI FireGL V8600 – 3D Studio (preMax) thru Max 2011 Design
  • Alan Lorence
    October 31, 2011 at 12:24 pm
    The previous poster was talking about the standalone application version of particleIllusion.
    In After Effects you should be able to use pI on your farm without activation. I assume you mean AE CS5, not AE 5.0, right?
    Alan.
    Alan Lorence
    Product Manager
    GenArts, Inc.
    http://www.genarts.com
  • Rob Holmes
    October 31, 2011 at 2:44 pm
    Yes, AE CS5. I think we are already talking privately. I appreciate it. I’ll try your suggestions:
    Try two things:
    1) Delete the emseldata.dat file that is in Documents/wondertouch/pIAE
    2) Reset your AE prefs. Restart AE while holding down the Command + Option + Shift keys (Mac) or Control + Alt + Shift (Windows), and you are presented with an option to delete the preferences.
    Then open AE, add pIAE and things should be back to normal (emitter selection dialog should show).
