Activity Forums Adobe After Effects Secondary Fluid Animation in AE
  • Szymon Hałaszuk
    May 31, 2017 at 9:52 pm
    It looks like some particle generator with inherited velocity and then roughen edges applied.
  • Nitin Burli
    June 1, 2017 at 1:02 pm
    Hi Szymon, what do you mean be inherited velocity? Will I have to create a shape layer, track it to to the object and apply a particle generator after?
  • Szymon Hałaszuk
    June 2, 2017 at 9:55 am
    There is an option in Particle Systems II or Particular (but you have to have license to use Particular), tab Physics that is called ‘Inherit velocity’. That means particles will inherit velocity from emitter. In the animation you can see some ‘blobs’ moving towards the phone and i think it could be made this way.
