Activity Forums VEGAS Pro secondary display settings and monitor calibration
  • secondary display settings and monitor calibration
    Posted by Arthur Bueno on December 17, 2005 at 2:07 pm
    I’m using a large LCD (the DELL 2405FPW) for previewing HDV material. Can anybody tell me what the Vegas settings (in Preferences/Preview Device) should be?
    When I disable the “use color management” checkbox, the preview looks washed out, (little contrast and too light), and much worse then the same material in VLC player or BS player.
    So I ‘ve enabled color managment and set it at “sRGB Color Space Profile”, with the “use Studio RGB 16 to 235” checkbox disabled. Does that make sense?
    I have difficulty calibrating this monitor anyway: reportedly it is too bright by default. I don’t have real calibration software/hardware, but used the demo of Passmark Monitor test. When I try to set brightness and gamma on a test image through the Nvidia driver software, the TestPattern previewed from the Vegas Timeline (with settings as above) is too dark.
    Any tips are much appreciated.
    Gilles Pialat replied 20 years, 9 months ago 3 Members · 5 Replies
  • Gilles Pialat
    December 17, 2005 at 5:08 pm
    Hi Artur,
    I can’t answer to you but i have a question about Vegas and HDV preview on an external LCD monitor.
    Actually, I use Vegas with DV footage and can preview video at full DV quality (25fps with no FX).
    Can I expect to preview HDV at full quality just like DV ?
    Which graphic card I need for this ?
    Thank You
    Gilles
  • Donatello
    December 17, 2005 at 10:24 pm
    vegas 5 or 6 ?
    the dell is only for previewing the HDV ? you don’t use it to edit V TL ?
    use graphic DVI out to DVI in connection on monitor ?
  • Arthur Bueno
    December 18, 2005 at 4:54 pm
    At full size (Preview-Full) I get a pretty good preview. Still the movement isn’t perfect, I only get a really fluent image when I set it to Preview-Auto, at half the width.
    With an m2t file on the timeline it plays less fluent then when I convert to cineform intermediate format.
    I changed my videocard from an Ati Radeon 9550 to an Nvidia 6800 GT (256 Mb) for this, but it doesn’t seem to help much.
  • Arthur Bueno
    December 18, 2005 at 4:56 pm
    Vegas 6 (material converted to cineform). I put the preview on the secondary display which is the big LCD. I connect it through the DVI ports.
  • Gilles Pialat
    December 18, 2005 at 6:09 pm
    Many thanks for those informations Arhur.
