Activity Forums Maxon Cinema 4D Second hand on a ticking clock
  • Second hand on a ticking clock
    Posted by Stu Pond on January 15, 2007 at 10:11 am
    I have to animate a ticking clock and the focus will be on the second hand. I could animate it as a sweep hand, but would rather the hand moved every second. Rather than animate this a frame at a time I was wondering if anyone has an expression that could just rotate the hand 6 degrees every second to replicate the movement of the hand.
    Cheers,
    stigWeard
    Stu Pond replied 19 years, 8 months ago 4 Members · 5 Replies
  • Mylenium
    January 15, 2007 at 5:36 pm
    You need just a few XPresso nodes. First add a Time node, set it to seconds. Take the output of that node into a FloatMath node which is set to floor. Then take this output into a Math node, set it to Multiply. Feed the rounded time into the first port, for the second port use a fiixed value of six. This will give your rotation. Plug the result in any of your object’s channels.
    Mylenium
    [Pour Myl
  • Brian Jones
    January 15, 2007 at 9:34 pm
    couple of small corrections, that would be FloatFunc not FloatMath and you’d want to add a Degree node (set to Degree to Radians) to take the value into the second hand
  • Lennart Wåhlin
    January 15, 2007 at 10:57 pm
    If you are in a hurry and are running R10 with MoGraph you can see if the StepCLOCK rig might work for you.
    http://www.tcastudios.com -> xfiles -> StepCLOCK Item 027
    Cheers
    Lennart
  • Mylenium
    January 16, 2007 at 6:00 am
    Yupp, thanks. Wasn’t in front of da beast. ;O) Thanks for following up.
    Mylenium
    [Pour Myl
  • Stu Pond
    January 16, 2007 at 3:58 pm
    Thanks very much for this folks – as is sod’s law, the client rejected my 3D idea and I have had to do it in AE in a different style.
    However, it hasn’t been entirely wasted – I will try the method anyway as part of my ongoing mission to learn Xpresso.
    Thanks again!
    stigWeard
