Activity › Forums › Apple Final Cut Pro Legacy › Second export through FCP and compressor
  • Second export through FCP and compressor
    Posted by Andy Morin on October 18, 2013 at 2:53 pm
    So i just exported a couple of videos through compressor as h.264 files and the audio is kindve low. Each of these files took about 4 hours to compress. Is it ok to just reimport the h.264 footage into tcp again, raise the audio meters and export? and if so what compression settings are recommended the 2nd time
    Steve Eisen replied 12 years, 11 months ago 4 Members · 6 Replies
  • Rainer Wirth
    October 18, 2013 at 2:58 pm
    Hi Andy,
    if you set your audio levels right in FCP let’s say -6db, you audio is fine in Compressor. I would go over again.
    cheers
    Rainer
    factstory
    Rainer Wirth
    phone_0049-177-2156086
    Mac pro 8core
    Adobe,FCP,Avid
    several raid systems
  • Andy Morin
    October 18, 2013 at 3:04 pm
    So i can send the newly compressed h.264 files back into FCP and send to compressor again? What settings would be o.k to use the second time without recompressing and keeping the quality?
  • Rainer Wirth
    October 18, 2013 at 4:28 pm
    No, you have to send the original FCP files with the new sound settings to compressor.
    cheers
    Rainer
    factstory
    Rainer Wirth
    Mac pro 8core
    Adobe,FCP,Avid
  • Nick Meyers
    October 18, 2013 at 11:45 pm
    you could try running through compressor again.
    i think it’s possible to raise the audio somehow, maybe with a filter
    and set the video to bypass.
    nick
  • Nick Meyers
    October 18, 2013 at 11:47 pm
    or you could try something like your original idea:
    inport into FCP, raise levels,
    and export using same settings, so no re-compression on the video
    not sure how that will work with H264, but worth a look, i guess
    nick
  • Steve Eisen
    October 19, 2013 at 5:19 am
    make sure your audio bit rate is at least 160 or higher.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Creative Pro Users Group
