Activity Forums Maxon Cinema 4D Seat cushion
  • Seat cushion
    Posted by Will Barber on June 14, 2010 at 2:33 pm
    Hi there,
    I’m modelling an armchair and can’t get the cushion/seat padding to work. The look i want is rather like caterpillar segments. I tried using the soft selection tool to raise the sections to look like the cushioning but when i do this it bring the edges away from where i want them to be fixed/flush with the seat.
    Is there a simple way to do this correctly? Any advice would be gratefully received.
    Will.
    Will Barber replied 16 years, 1 month ago 3 Members · 5 Replies
  • Adam Trachtenberg
    June 14, 2010 at 9:43 pm
    Can you post a pic of the look you’re going for? Caterpillar segments isn’t doing it for me. 😉
  • Will Barber
    June 15, 2010 at 8:44 am
    Yes here it is…
  • Will Barber
    July 5, 2010 at 1:02 pm
    Hi there,
    Here’s the link below:
    Will.
  • Brian Jones
    July 5, 2010 at 6:17 pm
    HyperNurbs with a relatively simple control cage is a much easier way to do it. A quickie example, this is not right but it should give you the general idea.
    889_chaircushion.zip
  • Will Barber
    July 6, 2010 at 8:25 am
    That helps immensely, thanks for the response. Think i was making it too complicated for myself.
    Cheers
    Will.
