Activity › Forums › VEGAS Pro › searching for markers
  • searching for markers
    Posted by Rick Dolishny on July 14, 2008 at 5:29 pm
    I’ve marked up a series of long-ish interviews and tried using markers. Which was working great until I needed to search for something, then the workflow fell apart.
    Is it possible to perform a search including information in a marker?
    Or would you go the subclip route (a little more work, and messy bins).
    Rick Dolishny
    Discrete Editors COW Leader
    http://www.thecreativeprocess.ca
    Gilles Pialat replied 18 years, 2 months ago 3 Members · 2 Replies
  • Adam Rose esq.
    July 14, 2008 at 7:17 pm
    you can always use the EDIT DETAILS tab, and change the dropdown to Markers, then search through them that way – was doing it this afternoon.
    also, could dbl click the timecode of that marker, copy it, then double click the timecode on the timeline (bottom right) and past the timecode in, and press enter – will take you to your mystery marker
  • Gilles Pialat
    July 15, 2008 at 5:24 am
    If you are using VP8, you can try this custom command :
    https://www.sonycreativesoftware.com/forums/ShowMessage.asp?MessageID=570599
