Activity Forums Avid Media Composer Searching for keywords using the comments section
  • Searching for keywords using the comments section
    Posted by Veronica Pinkham on May 15, 2017 at 8:31 pm
    It seems that it is not possible to search for keywords I include in the comments column – true? Would the best workaround be to make markers with keywords? I haven’t found a good thread discussing this. Thanks!
    Veronica Pinkham replied 9 years, 4 months ago 2 Members · 2 Replies
  • Glenn Sakatch
    May 15, 2017 at 11:16 pm
    Did you try “control F”?
    Just did a search for a word i put in a column called “help”, and it called up the word in the column
    Glenn
  • Veronica Pinkham
    May 16, 2017 at 12:07 am
    Yes, it is working now. That’s how I tried it before, didn’t work. Tried it again, now works! I suspect maybe the first time I tried I simply hadn’t saved/closed the bin, so it hadn’t registered the change yet. Silly me. Thank you!
