Activity › Forums › Broadcasting › searching for a video converter from Computer to PAL SDI or Component
  • searching for a video converter from Computer to PAL SDI or Component
    Posted by Sebastian Riezler on January 12, 2007 at 3:43 pm
    Hi all,
    We’re planning a show were we want to use three cameras(SD-SDI) and two computers as sources.
    There are no problems with the cameras but i once heard i have to downconvert the computer signals from whatever resolution they have to PAL so i can use them with our digital videomixer.
    do i need this downconverter for a SDI signal too or was this just for analog component signals.
    If i need a converter, does anyone of you know a good company/ model to purchase?
    thanks for your answers
    Riot
    Sebastian Riezler replied 19 years, 8 months ago 3 Members · 3 Replies
  • Bouke Vahl
    January 20, 2007 at 8:26 pm
    Anything wrong with a dirt cheap Decklink card?
    Bouke
    http://www.videoToolShed.com
    smart tools for video pro’s
  • Jerry Zorek
    January 22, 2007 at 3:44 pm
    If the video source from the computer is coming from a NLE like Final Cut then you would just build your video in PAL and use an AJA or Decklink card to pipe the video out. If the source of the computer video is your desktop or Powerpoint then you will need a scan converter and format converter. The Folsom Image Pro SDI should do the trick.
    https://video.folsom.com/products/index.cgi?index=1070327722_18404
    jerryz@bhphotovideo.com
  • Sebastian Riezler
    January 23, 2007 at 9:19 am
    @Jerry:
    thanks for your great help. this model is perfect for us!
    @bouke:
    i’m not sure if the decklink card can be used for desktop systems. i will have to check the specs sheet.
    anyway, thanks for your answer.
    rock on
    Riot
