Activity Forums Boris FX Particle Illusion Searching a way for importing position data from voodoo or icarus …
  • Searching a way for importing position data from voodoo or icarus …
    Posted by Dennis Fassbaender on May 22, 2008 at 9:04 am
    Hi!
    At ths time im using Voodoo and Icarus for tracking my footage and it works very, very well.
    But i don´t know, how i can import that position data into particle illusion.
    I whanted to try importing LWS-Date to cinema 4d and than use the ParticleIllusionExporter- but there is no working Download-Link for this free plugin.
    Is there an other way?
    Dennis Fassbaender replied 18 years, 4 months ago 2 Members · 2 Replies
  • Alan Lorence
    May 22, 2008 at 1:03 pm
    When you export the Voodoo tracking data as “text file”, what information does it provide? If you can modify the data (using a spreadsheet program perhaps) so you only have the following info on each line:
    frame_number x_pos y_pos
    Then you can import that into particleIllusion (from text file).
    I’d check out Voodoo now and see what data is added to the file, but I have too much to do right now already.
    Alan.
    http://www.wondertouch.com
  • Dennis Fassbaender
    May 22, 2008 at 6:32 pm
    Thanks for that c4d-pi-exporter!
    It works VERY FINE!
    Greets,
    Dennis
