Activity Forums Apple Motion Seamless Particle Loops?
  • Seamless Particle Loops?
    Posted by Randall Bennett on June 19, 2005 at 8:50 pm
    Motion, as you all probably know, has great particles. I typically only use motion to create abstract backgrounds, or other basics (since it is so great) but I was wondering how you recommend making a seemless loop? Typically, I’ll just render out the backround file to be 3 minutes, but with our clipstore I can’t be rendering out 3 minute files for air. Ideally, i’d like to make much shorter seamless loops (10-15 sec) but I havent found a setting similar to ‘evolution’ in the fractal noise plugin in AE.
    Let me know if there is a way to do it.
    Randall Bennett
    Broadcast Designer
    KSL-TV, Salt Lake City, UT
    Randall Bennett replied 21 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
