Activity Forums Adobe After Effects Seamless loops with particles
  • Seamless loops with particles
    Posted by Joakim on May 19, 2005 at 8:07 am
    I’m creating a starfield flythrough and need the clip to be seamless and looping. What’s the best way to approach this job and should I look at this from a different approach?
    I can use a lot of files of photoshop generated stars and zoom through a set of starfields, then I can set them to exactly overlap and create my seamless transition. Is there another way? It’s pretty interesting to try to get the behaviour to be nice and even but I think that if I play with the speed and velocity controls enough it might look ok, its very tedious to do it this way though.
    If I use the particle generator I think I will not get a seamless clip as I can’t cut the end into the start perfectly.
    Thanks for any tips on how to approach this.
    Ace Billet replied 21 years, 4 months ago 2 Members · 3 Replies
  • Ace Billet
    May 19, 2005 at 9:09 am
    Here what I did when I needed a seamless background loop:
    put the stars / background in a fresh comp.
    depending on what’s going on in the frame, go to 2 sec from the beginning of da comp.
    This will be the first frame of the new background loop. We’ll refer to it as frame X
    duplicate the background, move it to the end of your comp so that frame X is also the last.
    Now animate opacity for top layer from 0 to 100%, 100% is frame X.
    define work area from frame X (bottom layer) to frame X (top layer)
    render away – get a movie – loop it ad infinitum.
    sorry for the ayato style lame english, im under some nasty flu.
    cheers
    ace
    Intel Inside, the world’s most popular warning label.
  • Joakim
    May 19, 2005 at 9:38 am
    Nothing wrong with the English but plenty wrong with my lame knowledge of AE so far.
    Am I able to do that with the effect filter generated footage?
    I’ll go and have a play now, thanks for the tip.
  • Ace Billet
    May 19, 2005 at 3:11 pm
    Not to worry my friend.
    After Effects is the first piece of software I use that caused my to talk to myself ALOUD alot,
    trying to figure how to do stuff logically.
    as the saying goes there’s more than one way to skin a comp …
    cheers
    ace
