Activity › Forums › VEGAS Pro › seamless frames in animated movie with SV
  • seamless frames in animated movie with SV
    Posted by Cal North on June 7, 2011 at 4:19 pm
    Creating an animated movie, right now using a video editing program and importing flash animation.
    My question is, and I’m not even sure what this is called, if the frames overlap and don’t match — you get that awful jerky effect on the eye — where an image jumps or moves position — if I overlap the frames and they match — it’s seamless, gives the illusion of movement.
    Maybe this is called matching or synching? I’m not sure. I don’t have AE but am wondering if there’s a tool to use to fix this? In Sony Vegas? Or if I have to make sure the backgrounds match, which is going to be almost impossible.
    It’s a way to make the entry and exit of each frame in a clip, seamless so it views as a fluid animated movie.
    Cal North replied 15 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
