Activity › Forums › Adobe After Effects › Seamless Cuts
  • Seamless Cuts
    Posted by Chris Vickers on October 7, 2014 at 12:22 pm
    Alright, just watched this video, I’m interested in how hes made the “seamless” cuts. Obviously there’s a huge amount of time ramping across the whole piece which helps but there’s a ton of camera movement added in to aid transitions – its clearly been worked on a huge amount but there’s so much of of it i’m sure he must be using a plugin: https://vimeo.com/108018156
    Any thoughts would be appreciated, it’s more of just seeing a great piece and wanting to lift the veil a little.
    Many thanks
    Chris
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Daniel Waldron replied 11 years, 10 months ago 4 Members · 4 Replies
  • Daniel Waldron
    October 7, 2014 at 3:05 pm
    That’s an awesome video.
    Everything I saw looked like it could be done with some scaling, time-remapping, maybe some motion blur, and good old-fashioned editing. The stellar camera work also helps. I suggest downloading the clip and moving through the transitions frame by frame to see what’s happening.
  • Richard Garabedain
    October 7, 2014 at 3:53 pm
    Ya, probably just lots of time remapping. What might make a project such as this easier to produce is if you applied your time remapping to a slider with values from -2 to +2(or whatever you want). This way you could just animate the slide instead of lots of painful time remapping.
    Also. have you ever put a wiggle on time remapping? It makes a pretty cool effect. You could even add a separate slider for the wiggle.
    Also probably doesn’t hurt if you shoot your footage at a higher frame rate.
  • Derek Boettcher
    October 8, 2014 at 5:20 pm
    I doubt he is using a plugin to get the “seemless” cuts. A lot of his cuts appear to be extremely well planned out with camera motion. If you notice, most of the cuts occur while the camera is moving, creating a motion blur, then a quick 3-5 frame fade will make it feel like the cut was “seemless.” That’s probably how he got the feel of it. Other than that some of it may have been done in post using motion blur etc. but my guess would be good pre-production.
    Best,
    Derek Boettcher
    Creative Management
    BTH Media Group
    https://bthmedia.com
  • Daniel Waldron
    November 6, 2014 at 5:10 pm
    Here’s some editors commenting on the various techniques that may have been used in the video:
