Activity › Forums › Blackmagic Design › SDI Video / Analog Audio?
  • SDI Video / Analog Audio?
    Posted by Adam Oas on April 11, 2005 at 5:29 pm
    Is it possible with a Decklink Extreme to input SDI video while taking an analog audio input?
    I don’t seem to be able to get any SDI audio out of my Panasonic AJ-D450, and am hoping I can still use the SDI video. When I select Analog video input on the decklink it gives me audio levels, so i think it might be a issue with the deck, but don’t have any way to check if there is any audio coming out of the SDI. According to my panny’s manual, menu item number 720 is supposed to activate SDI embedded audio, but it doesn’t seem to make a difference.
    Powermac dual 2.5
    Decklink Extreme, latest SW updates
    FCP HD 4.5
    Video shot on a Panasonic Ajd810ap
    Uwe Klimmeck replied 21 years, 5 months ago 4 Members · 7 Replies
  • 7 Replies
  • Yves De muyter
    April 11, 2005 at 5:48 pm
    As far as I know, this is not (yet) possible.
    Setting the input to analog switches the video-input to analog too.
    -Yves
  • Adam Oas
    April 11, 2005 at 6:27 pm
    I was able to get thru to Panasonic tech support who had to forward me on to an Engineer, and they tell me that you have to have both the SDI and the seperate AES/EBU cards to get embedded audio on SDI out of a Panasonic Aj-d450. Unfortunately, they don’t make the AES/EBU card for my deck anymore.
    So i’m out of luck for SDI video untill it’s possible for the Decklink to take seperate SDI video & analog audio.
    Luckily i have enough spots on my patch panel to add component routing, but it’s a bit of a bummer.
  • Uwe Klimmeck
    April 11, 2005 at 8:41 pm
    Hi Adam,
    strange thing with the Panasonic.
    If it really doesn’t work you might try an SDconnect box ’cause it embedds/de-embedds SDI plus audio from evereywhere.. I don’t know how it’ll work for you, but maybe worth a try as they do a 15day evaluation program and a fantastic tech-support. I am happy with mine.
    https://www.convergent-design.com/
    Greetings
    Uwe
  • Paul Thurston
    April 12, 2005 at 4:27 pm
    Hi Uwe,
    Does the embedded audio, coming out of the SDconnect, work well with your DeckLink card?
    I purchased a DeckLink Pro and a Miranda AMX172-P110 SDI AES/EBU Audio Embedder/Multiplexer and it did not work. The Miranda outputs an embedded signal that the Decklink Pro software cannot decipher correctly (causing the captured audio to sound full of digital audio artifacts and high pitched noise).
    I used this setting with a PC computer and Premier Pro 1.5. It was an awful experience, and an expensive mistake.
    -Paul Thurston
    Santiago, Chile
  • Uwe Klimmeck
    April 12, 2005 at 4:57 pm
    Hi Paul,
    I use it the other way: Only output – but this is working fine.
    My DecklinkPro SDI-out goes to SDconnect SDI-in. SDconnect de-embedds the audio and the AES/EBU out from SDconnect goes thru a Finalizer to DigiBeta.
    I’m having problems with Edit to Tape when I use SDconnect to control the DBeta and so I use RS-422 from Decklink.
    Greetings
    Uwe
  • Paul Thurston
    April 13, 2005 at 6:00 am
    Thanks for the report Uwe,
    I’m wondering:
    1) If you send from your Digital Betacam machine, audio and video as separate into the SDconnect.
    2) If then you have the SDconnect embed the audio into the SDI signal.
    3) And then, when you capture media through your Decklink Pro card using this signal, does Decklink Pro disembed this audio correctly?
    -Paul
  • Uwe Klimmeck
    April 13, 2005 at 10:26 am
    Hi Paul,
    I don’t know as I digitize DBeta SDIwith embedded audio from a Sony. Sdconnect does de-embeddd the audio ’cause I monitor audio from SDconnect’s analog outputs while digitizing. But the digitizing itsels goes: DBeta SDIout – SDconnect SDIin – SDconnect SDIout – Decklink SDIin.
    A fine thing is SDI legalizing in SDconnect. I can turn it off for digitizing and turn it on for playouts.
    So I am always legal 🙂
    Greetings
    Uwe
