Activity Forums AJA Video Systems SDI v SDTI
  • SDI v SDTI
    Posted by Karim Zouak on August 11, 2005 at 8:40 pm
    I’ve got a KONA 2 that I’m trying to interface with a DVCAM deck, and I’m trying to keep the signal digital. The facility where I work runs analog to/from the DVCAM deck, using the dBeta as a transcoder, but I’d like to keep the signal digital (and keep the dBeta deck free). Our DVCAM deck has a SDTI (QSDI) interface on the back (there is an SDI add-on board, but we don’t have it) which is, as I understand it, incompatible with the SDI format the KONA2 uses. I’ve tried finding out more about this online, but have had little luck with my research so far.
    Can anybody tell me what the differences are between the formats, and if there is a converter between them?
    thanks
    Karim Zouak
    Karim Zouak replied 21 years, 1 month ago 6 Members · 6 Replies
  • Jerry Hofmann
    August 11, 2005 at 9:22 pm
    I’ll wager you need the SDI board, but you might ask Rudy in AJA support about an alternative if they have one… email support@aja.com, Rudy or one of his excellent support folks will get back promptly I’ll wager.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • David Battistella
    August 11, 2005 at 10:21 pm
    It looks like SDTI is a SONY specific interface for doing high speed or faster than real time transfers into SONY edit stations. This is a sony specific protcol and I doubt that the AJA supports it via the HDSDI/SDI inputs.
    It is also used for machiine to machine dubbing. But from what I am reading here
    https://www.sony.ca/dvcam/manuals/DSR-1800-1800P.pdf
    it’s all sony specific.
    David
  • Fred Connors jr.
    August 11, 2005 at 10:55 pm
    David is correct, the SDTI is will not work with standard SDI interfaces.
    Fred
  • Tony
    August 12, 2005 at 5:08 am
    Karim,
    SDI in this case is not Strategic Defense Initative instead it stands for
    Serial Digital Interface, SDTI is Serial Digital Transport Interface.
    SDTI is not unique to Sony only. Sony and Panasonic decks can have both SDI and SDTI inputs and outputs.
    In an nutshell the only method to obtain a true digital clone is via SDTI not SDI.
    SDI dubs results in compression taking place each time. SDTI does not.
    The Kona 2 does not have a SDTI inputs only SDI.
    Tony Salgado
  • Jeff Barnes
    August 12, 2005 at 12:51 pm
    Yes, it is also used by EVS within their Live production workflow.
    “re-compression” may depend upon the codec being used on the recieving end but SDI inherently does “re-sampling” in a component digital fashion. Thus, creating some degredation, however seemingly acceptable to most.
    SDTI, while ‘neat’ has never really found traction being a file transfer method. Fibre Channel coupled with San solutions have almost negated most SDTI develpement into workflow solutions. Now, primarily a source of confustion. 😉
    Jeff Barnes
    jbarnes@senecacom.com
    304-291-3888
  • Karim Zouak
    August 12, 2005 at 1:24 pm
    Thanks very much everybody, I guess I’m going analog then!
