Activity Forums AJA Video Systems SDI Outputs no signal
  • SDI Outputs no signal
    Posted by Lars Larson on August 13, 2012 at 10:26 pm
    Hello,
    I’ve been using the Kona 3 into a Panasonic BT-LH1700WP to better monitor my editing sessions. But now, for some reason, the SDI output I had been using isn’t registering any output.
    The inputs on the monitor itself are fine: they work when attached directly to my camera. Also, Final Cut Pro is recognizing that the Kona card is active.
    Thoughts? Help?
    Thank you
    Shane Ross replied 14 years, 1 month ago 3 Members · 2 Replies
  • Gary Adcock
    August 13, 2012 at 11:46 pm
    [Lars Larson] ” But now, for some reason, the SDI output I had been using isn’t registering any output.”
    you do not mention what formats and frame rates.
    Are you sure that your input source is correct on the montior?
    shut off FCP open the Aja control Panel ONLY
    Turn on Bars if they are not on already.
    Still No signal?
    Call tech support.
    gary adcock
    Studio37
    Post and Production Workflow Consultant
    Production and Post Stereographer
    Chicago, IL
    https://blogs.creativecow.net/24640
    follow me on Twitter
    @garyadcock
  • Shane Ross
    August 14, 2012 at 4:14 am
    Card might need to be reseated too. If you are brave enough to open the machine and do that. If you didn’t install it, I’d have the person who did do this, or let tech support walk you through this.
    Shane
    Little Frog Post
