Activity Forums Blackmagic Design SDI output resolution to monitor
  • SDI output resolution to monitor
    Posted by Frank Ruggiero on November 22, 2009 at 5:21 pm
    Hi Blackmagic,
    Can anyone explain this to me? If I am creating graphics at 720×486, how does the Blackmagic SDI work with that when I am sending it over the SDI cable? Isnt SDI a resolution of 720 x 480 (Smpte259M)?
    I want to work in After Effects and Premiere at 720×486. Does the Blackmagic compensate for my output by removing 6 lines before outputting? Or do I always have to work in 720×480?
    If anyone can clear that up, I would greatly appreciate it.
    Thanks.
    Frank
    Joshua Helling replied 16 years, 9 months ago 3 Members · 3 Replies
  • Bob Zelin
    November 22, 2009 at 11:48 pm
    everything stays at 720×486. 720×480 is if you have chosen to work in DV resolution.
    bob Zelin
  • Frank Ruggiero
    November 22, 2009 at 11:58 pm
    Hi Bob,
    Thanks for answering my question. I have always worked in 720×486, but where it is confusing is the SDI. Is SDI a 720×480 resolution? A monitor company is telling me that SDI is only 480 scanlines. SO what would that mean when I try to output through the card. Does the Blackmagic take my 486 signal and alter it to deliver it to 480?
    Or am I just mistaken or have bad information.
    Thanks Bob.
    Frank
  • Joshua Helling
    November 24, 2009 at 1:15 am
    To add on what Bob said. 720×486 is D1 resolution. Everything out of our card will be that res (even in a DV Project). The extra lines are added to make a signal that will typically be expected by SDI or analog equipment.
    DV, and MPEG2, are typically saved at DV resolution which is 720×480. However, if you are editing in a DV editing mode with BMD cards the timeline is 720×480 but the output will be 720×486 (2 and 4 lines are added to prevent scaling of the image). This is refered to as a DV-D1 conversion and is fairly common in these types of apps (it typically happens behinds the scenes).
    I hope that helps.
    Sincerely,
    Joshua
    Director of Support
    Blackmagic Design Inc.
