Activity Forums Blackmagic Design SDI Output on DeckLink HD Extreme
  • SDI Output on DeckLink HD Extreme
    Posted by Peter Heinrich on June 27, 2009 at 12:44 pm
    I am intend to use a DeckLink HD Extreme card, because it provides two SDI output channels.
    From the description it is not absolutely clear if it is possible to play different clips on each SDI output channel at the same time.
    Or is one channel the main playout channel and the other one is only for monitoring?
    Thanks in advance for an answer.
    Best regards
    Peter
    Peter H.
    Kristian Lam replied 17 years, 2 months ago 3 Members · 2 Replies
  • Bob Zelin
    June 28, 2009 at 12:03 am
    this is the correct answer.
    bob Zelin
  • Kristian Lam
    June 30, 2009 at 6:13 am
    The 2 outputs are the same and simultaneous.
    regards
    Kristian Lam
    Blackmagic Design
