Activity Forums Media 100 SDI output from M100.. Embedded Audio??
  • SDI output from M100.. Embedded Audio??
    Posted by Maxwell Federman on June 13, 2008 at 6:18 am
    Hello,
    Here’s your chance to be a hero:
    Can anyone recall if the SDI option for the Vincent Junction Box will output SDI with embedded audio?
    Also, does the SDI output support output of typical (720×480 or 640×480) programs; or does it require media that was captured from the SDI input before editing??
    Your help is greatly appreciated
    Max
    Maxwell Federman replied 18 years, 2 months ago 3 Members · 3 Replies
  • Kieran Matthew
    June 13, 2008 at 10:08 am
    Hi Max,
    [Maxwell Federman] ” Can anyone recall if the SDI option for the Vincent Junction Box will output SDI with embedded audio? “
    No it doesn’t, I’m afraid, you have to use the AES/EBU audio in & out.
    [Maxwell Federman] “Also, does the SDI output support output of typical (720×480 or 640×480) programs; or does it require media that was captured from the SDI input before editing??
    Anything on your timeline comes out of the SDI outputs regardless of source, but I’m not sure what happens in non-DV resolutions. Perhaps someone else can confirm?
    K
  • Paul Bertham
    June 13, 2008 at 10:41 pm
    yeah, i can!
    unflexible horseballs it is!
    sorry for my negative stuff, but i´ve never seen so unflexible hardware as this what we are talking about.
  • Maxwell Federman
    June 13, 2008 at 11:46 pm
    Thank you, Kieran.
    I appreciate your assistance.
    I am considering all options I have/may have for feeding SDI into a new KulaByte encoder.
    Our old Media100i system is an option I have been considering, that would leave our AJA cards free for other jobs.
    Thanks again for your assistance!
    Max
