Activity Forums Live Events & Streaming SDI Input Projectors
  • Joel Hufford
    July 25, 2013 at 9:21 pm
    Hi Bill,
    Given the size of projector you’re asking after, I think you’re going to have better luck sourcing one that has HDMI inputs and then purchasing a small converter to go from HD-SDI to HDMI.
    I would recommend checking this one out from AJA:
    AJA Hi5 Mini Converter. If you need it, they also make a 3G HD-SDI to HDMI mini converter, but it’s a bit more expensive.
    What exactly are you going to be using the projector for?
    joel
    Corporate and Special Event Staging Services
    http://www.pacificstaging.com
