Activity Forums Apple Final Cut Pro Legacy SDI audio levels
  • SDI audio levels
    Posted by David Davidson on July 21, 2005 at 6:48 am
    When sending perfectly mastered audio over an SDI channel–be it HD or SD–would there ever be an occasion that a deck would show overmodulation of signals? We’ve sent a SDI stereo pair to a D5 w/ the PCM input channels to unity using a blackmagic HD card w/ a FCP 4.5 system. I’m curious to know, if the digital audio is properly limited, would sending audio via SDI need any level adjustment on the deck?
    FCP doesn’t add any gain whatsoever–as far as we know–because mastering Digibeta via SDI produces excellent repeatable results for audio.
    Has anyone had such an experience where SDI audio was overmodulated or peaked? Sorry for cross-posting!
    david
    David Davidson
    Visual Effect Supervisor
    solventdreams, llc
    http://www.solventdreams.com
    4222 santa monica blvd
    los angeles, ca 90028
    323 906 9700
    dv@solventdreams.com
    David Davidson replied 21 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
