Activity Forums Blackmagic Design SDI audio levels
  • SDI audio levels
    Posted by David Davidson on July 21, 2005 at 1:22 am
    Did a layoff to D5 this weekend with a HD Pro card. Mixer had provided a properly limited file, clamped on top and bottom correctly with no distortion. When imputting into the D5, we noticed in certain places that levels were a bit overmodulated. The deck was set to SDI audio in, PCM.
    Provided the audio was mixed correctly, does SDI embedded audio just go straight across w/o any level adjustment?
    David Davidson replied 21 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
