Activity Forums Broadcasting SDI audio levels
  • SDI audio levels
    Posted by David Davidson on July 21, 2005 at 6:47 am
    When sending perfectly mastered audio over an SDI channel–be it HD or SD–would there ever be an occasion that a deck would show overmodulation of signals? We’ve sent a SDI stereo pair to a D5 w/ the PCM input channels to unity using a blackmagic HD card w/ a FCP 4.5 system. I’m curious to know, if the digital audio is properly limited, would sending audio via SDI need any level adjustment on the deck?
    FCP doesn’t add any gain whatsoever–as far as we know–because mastering Digibeta via SDI produces excellent repeatable results for audio.
    Has anyone had such an experience where SDI audio was overmodulated or peaked? Sorry for cross-posting!
    david
    David Davidson
    Visual Effect Supervisor
    solventdreams, llc
    http://www.solventdreams.com
    4222 santa monica blvd
    los angeles, ca 90028
    323 906 9700
    dv@solventdreams.com
    Armagnax replied 21 years, 1 month ago 3 Members · 2 Replies
  • Jon Zanone
    July 26, 2005 at 12:28 pm
    Audio is seperate from an SDI signal, no? My experience with SDI is that it’s a seperate signal from audio. In my case, I’m sending out SDI video, and analog audio (it is possible to send digital audio, but we’re not set up that way…).
    If you are sending out a proper signal from your deck, you should be getting good audio. Is there a DA somewhere in the signal path? Is it possible you are sending an analog audio signal, but seeing a digital signal in your meters?
    Jon
  • Armagnax
    July 27, 2005 at 8:54 pm
    We use SDI for audio all the time. It’s great. no messing with levels necessary what comes out goes in. The advantage of Digital.
