Activity Forums Blackmagic Design SDI and analog audio
  • SDI and analog audio
    Posted by Karsten Runerheim on May 25, 2007 at 7:08 am
    Hi!
    Trying to capture SD SDI video (the video goes through a standards converter that does not embed sound) and analog audio at the same time in Premiere Pro 2. This does not seem to work. No audio. Does the Decklink HD extreme assume that sound is embedded in the SDI signal? Or is there a setting I have missed?
    Regards
    Karsten
    Luke Maslen replied 19 years, 4 months ago 2 Members · 1 Reply
  • Luke Maslen
    May 28, 2007 at 4:34 am
    Hi Karsten,
    Please open the DeckLink control panel and set the input connections to SDI and Analog XLR audio. That should be the solution.
    Regards,
    Luke Maslen
    Blackmagic Design
