Activity Forums Blackmagic Design SDI A & B on MultiBridge Extreme
  • SDI A & B on MultiBridge Extreme
    Posted by Steve Cohen on March 30, 2009 at 6:53 pm
    We have several Black Magic Multibridge Extreme units here and had noticed there is an SDI Input A & B as well as an Output A & B.
    What are these for?
    Can you have 2 different SDI inputs connected and switch between them in the preferences?(I’ve never seen a setting for this)
    Thanks in advance.
    Steve Cohen
    Senior Editor
    O2 Media Inc.
    Thomas Rued replied 17 years, 4 months ago 3 Members · 2 Replies
  • Kristian Lam
    March 30, 2009 at 9:31 pm
    Hi Steve,
    Input B the second link of a dual link HD-SDI connection for use with the HDCAM-SR while capturing 4:4:4 RGB 10-bit HD. It cannot be used as a separate SDI input.
    regards
    Kristian Lam
    Blackmagic Design
  • Thomas Rued
    May 4, 2009 at 8:44 am
    Hi Kristian,
    I’m having a similar problem – is there any way you can capture Full HD from two individual sources at the same time using the MultiBridge?
    (I’m using the MultiBridge Pro)
    Best
    Thomas Rued
