Activity › Forums › Sony Cameras › SDHC HIGH-SPEED Card Reader
Posted by Jay Gladwell on August 31, 2009 at 4:10 pmIs there such a thing as a high-speed SDHC card reader?
The transfer time from my SDHC cards (16GB) to the backup drive (BPAV files) is 75 minutes.
Is there a faster method?
TIA
Steve Wargo replied 17 years ago 5 Members · 8 Replies -
Noah Kadner
August 31, 2009 at 4:15 pmHuh? Which reader and computer is that? I use a standard USB-2 to my Mac Pro and it’s maybe 10 minutes for 16GB tops.
Noah
Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera!. Unlock the secrets of the 24p, HD and Final Cut Studio.
Now featuring the Sony EX1 Guidebook, Panasonic HVX200, and Panasonic DVX100.
https://www.callboxlive.com -
Craig Seeman
August 31, 2009 at 4:16 pm???
You shouldn’t assume the problem is with most readers.
With SDHC I get 2x with ClipBrowser CRC on and 4x with it off. In other words it takes me either about 28 minutes or 14 minutes to copy from SDHC from 16GB (about 57 minutes). I’m just using a Sandisk multi card reader, an old one too as it only list SD and not SDHC support. -
Craig Seeman
August 31, 2009 at 4:17 pm[Noah Kadner] “it’s maybe 10 minutes for 16GB tops”
Noah, you know you’re supposed to CRC On. -
Noah Kadner
August 31, 2009 at 4:40 pmSounds like a USB-1 reader or port in use.
Noah
Clint Fleckenstein
August 31, 2009 at 5:02 pm“Sounds like a USB-1 reader or port in use.”
Never plug a card reader into your keyboard’s USB port if it has one – you never know what you’ll get. Most likely USB-1, at least on older equipment. On my Mac keyboard it also pops up an error saying that the port doesn’t provide power to the reader, it’s only a data connection.
Cf
Steve Wargo
September 1, 2009 at 9:55 amWhat was the question again?
just kidding. Seems like you’ve got a bottleneck somewhere.
Steve Wargo
Tempe, Arizona
It’s a dry heat!Sony HDCAM F-900 & HDW-2000/1 deck
5 Final Cut (not quite PRO) systems
Sony HVR-M25 HDV deck
2-Sony EX-1 HD .Ask me how to Market Yourself using Send Out Cards
