Activity Forums Compression Techniques SD_DVD apple compressor strange issue
  • SD_DVD apple compressor strange issue
    Posted by Nayim Saati on December 4, 2009 at 7:48 pm
    hey guys, im having issue with some HD video that m trying to compress down onto a DVd using apple compressor:
    im using the dvd best quality settings
    Average bit rate : 7.7
    max bit rate : 9.0
    now when i export using these settings get a freaky pulsating and pixlezation of only 3 shots which you can see here: ( the problem starts around 20 seconds and gets worse and worse)
    https://vimeo.com/7987267
    so i called apple and they told me to use compression markers for this sequence to make them all I-Frames , i did so and exported only that sequence out and it looked fine. so i decided to export the rest of my 28 minute sequence with the same settings and after a 6 hour render i burned the dvd and to my shock there is the same problem. any ideas please?!?! im really struggling to get this out to some important clients and i cant change the shots even though when played in the sequence the shots look fantastic. ive tried some de-interlacing filter from compressor using blur but that doesn’t help much..
    im on an apple g5
    dual 2.7
    6.5gb ram
    final cut 6.0.6
    compressor 3.0.5
    Tom Brooks replied 16 years, 9 months ago 3 Members · 3 Replies
  • Rich Rubasch
    December 5, 2009 at 2:08 am
    this is a worst case scenario really because moving water is the toughest for MPEG-2….everything is moving all over the frame. I even see this pulsing on our Charter HD feed on similar shots.
    BitVice is an option you could try….download a demo? Otherwise try a VBR and the only other thing I can think of is did you go to the frame controls box and turn them on? Not sure if that would do it but worth a try since you are downconverting HD to SD.
    Rich Rubasch
    Tilt Media Inc.
    Video Production and Post
    Owner/President/Editor/Designer/Animator
  • Nayim Saati
    December 7, 2009 at 12:18 am
    if neither work are there any other techniques for dvd compression besides mpeg2
  • Tom Brooks
    December 7, 2009 at 4:08 pm
    MPEG-2 is really your only choice for SD DVD. I would go the opposite direction and use CBR compression. Whenever I run into pulsing on the GOP transition I try CBR.
