Activity Forums Apple Final Cut Pro Legacy SD video squishing on widescreen TV
  • SD video squishing on widescreen TV
    Posted by Zach Rose on June 3, 2009 at 3:53 am
    Hey All.
    I’m trying to put one line of white text on a black background, burn it to a DVD, and play it on a widescreen tv. The only problem I’m having right now is that the text seems to be squished vertically about 80% or so. I’m using what I believe to be a vanilla NTSC setting (720 x 480).
    I notice in the Timeline Settings of FCP that there are two things that might help solve this problem: a Pixel Aspect Ratio and an Anamorphic 16:9 checkbox. I’m guessing it would be good to check the 16:9 option. Should Pixel Ratio be NTSC or Square?
    Thanks.
    David Hartnett replied 17 years, 3 months ago 2 Members · 1 Reply
  • David Hartnett
    June 3, 2009 at 3:07 pm
    Yes, check the anamorphic option. Leave pixel aspect ratio as NTSC, not square. You may have to set these first, then put your text on the timeline.
    Editor – Speakeasy
    http://www.speak.co.uk
    FCPS & CS3
    6 Intel Macs w/Kona 3/LH
