SD Video on Blu-Ray: To Upscale or Not to Upscale?
I have some old standard definition videos that I’m considering putting on blu-ray disc. Seems I have 2 choices:
1) Upscale the videos to HD Resolution – I’ve been experimenting using the BorisFX “UpRez” plugin, which supposedly can improve the quality of the original video more than just scaling it up. My source footage is from VHS tapes, and from what I’ve seen so far, there’s maybe a SLIGHT improvement over the original SD capture…
2) Leave the videos in SD resolution using a standard DVD variable bitrate knowing that I’ll be able to fit a LOT of video onto a single blu-ray disc.
The question for me comes down to quality and having these old videos look as good as they possibly can. At this point, I haven’t seen a huge noticeable difference in the upscaled HD render…and if the videos are going to look just as good playing back in SD resolution, I’d rather take advantage of the blu-ray disc capacity and have like 9 hours of video on a single disc without having the compression I would see on a regular DVD.
Has anyone else worked with SD video on blu-ray? What kind of settings do you use in terms of bitrate? When making DVDs (with under 1 hr 20 min of video), I’m using a variable bitrate of 8 mbps high / 6.5 mbps average / 4 mbps low for the best quality. Would the quality improve at all on a blu-ray disc using a higher bitrate? Or is that about as good as it looks before you just start increasing your file size for no reason?
Thanks in advance for your help!
