Activity Forums Panasonic Cameras SD version from HD
  • SD version from HD
    Posted by Peter Sassi on May 15, 2006 at 1:53 pm
    First of all thanks to all for the wealth of information i’ve found here and elsewhere on defining this P2 workflow.
    Question: Can I shoot 720p and simply drop it in some sort of SD timeline in FCP5 for delivery on BetaSp? These are regional commercials that i would like to future proof and get a better looking master. I have tried all maner of Timeline and what i can get is a letterboxed SD in 8bit uncompressed. But cant seem to noodle the right combination for a center-cut SD version. I’m not sure if it’s a matter of lack of horsepower (dual G5 on the way) or cockpit error.
    Peter
    FCP 5.04
    Blackbagic Extreme
    G4 Dual 1Ghz (Dual G5 on the way)
    2GRam
    Noah Kadner replied 20 years, 3 months ago 2 Members · 3 Replies
  • Noah Kadner
    May 15, 2006 at 4:39 pm
    Adjust the scale settings up in the clip’s motion tab for a 4:3 center extraction. FCP assumes you want 4:3 letterbox.
    Noah
  • Peter Sassi
    May 15, 2006 at 4:53 pm
    Noah,
    I hit on that solution too. If i scale up to 90% in a 960×720 timeline and set the Decklink to anamorphic i get a 4:3 centercut. It would seem there should be an easier way within FCP. Does 5.1 have any further solutions or do i need to upgrade to an HD card?
    thanks,
    peter
  • Noah Kadner
    May 15, 2006 at 9:08 pm
    Not really- what’s not easy about that?
    Noah
