Activity Forums Apple Final Cut Pro Legacy SD TV Sequence Settings & Photoshop Graphics
  • SD TV Sequence Settings & Photoshop Graphics
    Posted by Mark Fanjoy on February 8, 2010 at 7:33 am
    I am steadily learning how to properly set up my sequences for SD 4×3 output and to match my Photoshop and LiveType file settings to match the timeline. I think I’m close, but here is a new condition I’m hoping has a solution:
    Now when I view my Photoshop and LiveType files (graphics and fonts) in the FC timeline, they are blurry and have torn edges. However, when I output a sequence to a QT file and play it back (from the QT player), they are nice and crisp and look great. If I play that same QT file back using FC, they look the same as in the Canvas timeline playback, crappy.
    If I grab one of the PS or LT files in the timeline to extend its duration, the canvas window converts to a slightly smaller screen (with the sequence timecode appearing at the bottom) and the fonts all of a sudden look beautiful. As soon as I let go, everything reverts back.
    Is there a reason why I cannot view my timeline while editing in a resolution that matches what the output is demonstrating?
    Thanks in advance for any direction and pointers.
    Mark Fanjoy replied 16 years, 6 months ago 2 Members · 2 Replies
  • Rafael Amador
    February 8, 2010 at 9:57 am
    Hi Mark,
    To see things at full quality in FC, you need to see them in the canvas, with the canvas set at 100%, and fully rendered, otherwise FC is offering you a preview which quality will depends very much of your setting, footage, etc.
    When you are confident that the out put will be OK, you don’t need to work with a full quality image.
    Best,
    Rafael
    http://www.nagavideo.com
  • Mark Fanjoy
    February 8, 2010 at 8:59 pm
    Thanks, Rafael. I have a large Cinema HD Mac monitor and everything enlarged on my FCP layout. So sure enough, I lowered my canvas from 126% to 100% and the picture is much improved. Just did not realize that simple condition.
    I think I’m there now!
    Thanks again and best of luck.
    Fanjoy
    Wherever I am…I’m lost!
