Activity › Forums › AJA Video Systems › SD to SD Conversion not working on my Kona2
Jeremy Garchow replied 19 years, 11 months ago 5 Members · 15 Replies
Alexander Serpico
October 18, 2006 at 11:14 pmtoo bad ive been busy non stop today, so couldn’t call… going to now tho…
havent tested HD in yet either… but HD out does work fine.
hope this gets resolved, and is not a bigger issue than it seems…. -
Jeremy Garchow
October 18, 2006 at 11:20 pmThe workaround that AJA told me to do does in fact work.
Open control panel, set primary to 1080i29.97 then set the SD-SD conversion to whatever you want, then set your primary back to 525i29.97
Thank you AJA!
Jeremy
Alexander Serpico
October 18, 2006 at 11:21 pmHEY JEREMY!
I just discovered that the SD to SD conversion DOES WORK when choosing “Macintosh Desktop” as the Default Kona Output.
So, is the answer simply that it wont work any other way? Or is there a bug with the other Outputs?
Alexander Serpico
October 18, 2006 at 11:31 pmI just posted that it did work when choosing “Macintosh Desktop” as the Default Kona Output.
Then from there, all the other outputs work until you get to input passthrough… then it bugs out again.But … i guess… mine is working now?
Jeremy Garchow
October 18, 2006 at 11:32 pmThat must mean your mac desktop is set to 1080i (that’s usually the default). You are then performing the workaround.
Jeremy
