Activity Forums Apple Final Cut Pro Legacy SD to pro res?
  • Posted by Heidi Schrodinger on January 23, 2013 at 3:25 am
    I am hoping to submit a short film recently completed to a film festival. It was shot in SD on a Sony PD 150 but they require a pro res version for the festival- supplied on hard drive- if selected. How would I go about converting to Pro Res and should I expect good results or not? I have final cut pro x and compressor available and no budget left whatsoever.
    Thanks for your advice,
    Heidi
    ‘Getting back into making after a long time off’
    Heidi Schrodinger replied 13 years, 7 months ago 4 Members · 5 Replies
  • Heidi Schrodinger
    January 23, 2013 at 5:17 am
    or, forgive me my complete ignorance- is it already on Pro Res if edited as such originally?
  • Gareth Randall
    January 23, 2013 at 5:46 am
    If it was shot with a PD150 then it’s DVCAM. Since FCP can handle DVCAM natively, there’d have been no need to transcode it to ProRes before editing.
    To convert it to ProRes you can simply export it from FCP and choose “ProRes 422” as the export codec. Alternatively, if you already have an exported QT file of the finished project, you can open it in QT Player or MPEG Streamclip and export it as ProRes. Or you can use Compressor, but that’s a little more involved since its interface isn’t necessarily all that intuitive.
    Quality-wise, ProRes will look identical to the original.
  • Steve Eisen
    January 23, 2013 at 5:49 am
    The original was shot on DVCAM (720×480). If edited in DV, export a QT Movie, drag that file into Compressor and choose a ProRes preset. Do not change any dimensions. The file size will be significantly larger than the DV file.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Creative Pro Users Group
  • Rafael Amador
    January 23, 2013 at 6:36 am
    Or better:
    Edit in native DV, and when you have everything ready to export, change the sequence setting by Prores and set “Render in High Precision”.
    Avoid exporting to DV (recompression) and then converting somewhere else to Pores.
    rafael
    http://www.nagavideo.com
  • Heidi Schrodinger
    January 23, 2013 at 9:38 am
    Yes indeed, compressor is the most confusing piece of cr*p, I mean software, I have ever had to use.
    What I am hoping to do is allow the film to show well on a bigger screen. Have also heard of exporting as 720p to do this?
