Activity › Forums › DaVinci Resolve › SD Timeline Set-Up & Management for 2k delivery
  • SD Timeline Set-Up & Management for 2k delivery
    Posted by Shawn Convey on December 13, 2022 at 1:25 pm
    Hey all, I am about to (finally) start editing some footage I shot SD back in 2008 and I want to set up my Resolve timeline for success.
    It was shot on a DVX100a / 24p / SD with a RedRock Micro 35mm lens adapter (180° rotated image, baked in grain).
    I have a lot of footage and I want to make sure I am setting up my project / timeline correctly.
    Here’s the tech info:
    SOURCE FOOTAGE
    – 60hrs of legacy footage
    – SD Footage (Pana DVX100a w/ RedRock Micro 35mm lens converter (so baked in grain))
    – 24p (I think Panny’s 24p for the DVX line was a bit “different” than industry standard)
    – 720×480 / FoV 35° / Horizontal Resolution 490 Lines
    GOALS
    – 2k Delivery (possibly 4:3 possibly 16:9 if possible)
    – Non-Square pixel format (NTSC DV / .9)
    SOFTWARE
    – Editing Resolve Studio 18.1.1
    – Up-scale (res) Topaz Video AI (maybe)
    CONCERNS
    – What timeline resolution to edit in if end product is going to be upscaled?
    – If / When to us Resolves “Super Scale” settings (if in the end Topaz will be used (still not sure))
    – Filed Dominance / Pull Down – I had a lengthy chat with Joey D’Anna about a possible AE workflow BEFORE Resolve introduced their own real-time Pull Down feature… Now that they do have it I am a bit confused as to the best method.
    – The baked in grain seems to throw off some of the up-scale software (creating artifacts) I am still testing this but Topaz’s newer AI releases seem to be a bit promising… not sure
    I plan on taking the next week or so to ready the footage, as I have subtitles that have been done in older versions of premiere and I will need to account for that as well as rotating the image, getting the clips field dominance and pull-downs in order at the very least.
    I am looking for any and all Tips, workflow options, and “gotcha’s” that you can see.
    Thx!
    Shawn Convey replied 3 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
