SD storage: frightened & confused
OK, so i’ve read just about every thread about every storage option, hoping to make a decision, and the knowledge is impressive; however, with so many products it’s daunting.
so here’s the deal:
currently i’m doing some work for a new satellite channel that uses betaSP as it’s primary format. my system is set-up OK for DV (i have an older 500G LaCie BD extreme) and is fine for the short run, but SD is in the immediate future. so…
>G-Raid sounds great and a great price, but does it really do 2 streams of SD via FW800?
>Medea has the Rt3 with SCSI, Fibre, etc. but for that to work, if i understand it right, we’re in the 5-7k range.
>Then there’s the LaCie option, great price. my 500G BDE hasn’t failed me yet but i’m not a fan of not having a fan.
>Then if i were rich i’d get the Xraid w/fibre and call it good. spending that kind of dough seems ridiculous, but i don’t want to save money only to pay the difference in aggravation. that’s kind of a dream because i can’t really afford apple anyway.
also, i think i’ve decided to go with the aja ls over the decklink. the budget for all is about 3-4 k including the kona.
what would you do? — or any help would be more than welcome!
thank you in advance.
e. eric johnson iii
eric@lillcreates.com
lill creates: founder/executive producer
Water Channel: producer/virtual set operator+?
