Activity › Forums › Boris FX › SD Rendering From HD Project
  • SD Rendering From HD Project
    Posted by Terry Grider on February 18, 2012 at 2:39 am
    I have an HD project that is 1920×1080 with Boris Red Transition Effects in the timeline. When I export the project in HD, the effects render correctly. When I export to SD 720X480, the effects look as though they are not scaled to the SD resolution. Is this a project setting in Boris Red that is wrong?
    Terry
    Terry Grider replied 14 years, 7 months ago 2 Members · 2 Replies
  • Peter Mcauley
    February 21, 2012 at 1:09 pm
    Where are you setting the render size? Are you scaling on the host output or changing the host project settings? What host are you using?
    Peter.
  • Terry Grider
    February 21, 2012 at 3:06 pm
    Hi Peter,
    My Host is Premiere CS5.5. I have found that if I export directly from Premiere instead of queuing to Media Encoder, it works as expected. I don’t know if it’s an Adobe problem or something missing in the metadate sent to Media Encoder. Anyone else able to duplicate this scenario?
    Terry
