Activity Forums Apple Final Cut Pro Legacy SD – ProRes confused
  • SD – ProRes confused
    Posted by Paul Witcher on February 6, 2010 at 9:49 pm
    Hi Guys,
    I’ve been looking on the forum for tips on my problem, but I’ve ended up more confused then when I started.
    Question: I have a SD 16:9 ratio documentary I shot on a Sony HDR FX1 – this was originally edited in Adobe, the good news is this film has now been accepted by a Sky channel. Since I made this film I have brought a Mac and FCP v7.1 I have been editing my next project, shot in HD with ProRes all OK.
    Now, my plan is to re cut the SD doc in FCP for TV – so I will capture all the tapes and load into FCP, a total of approx 18 hours of tape.
    Can I edit with ProRes? from what I have read I would need a capture card to use ProRes? (which I don’t have) can I just capture direct from the camera? if so what are the correct capture settings? as I’m in the UK I have selected PAL in the easy setup and this will use Cinema Tools 23.98fps DV PAL.
    In the log and capture settings – which capture setting would I select DV PAL? my confusion is, there is an option in easy setup for ProRes – with this setting the sequence settings after capture are 720×576 aspect CCIR 601/DV PAL.
    I’m not sure what is right or wrong – the final delivery format is DV50.
    Sorry if I missing the obvious with this question. If anyone can point me in the right direction I would be most grateful.
    Paul
    Gary Ellison replied 16 years, 5 months ago 4 Members · 6 Replies
  • John Fishback
    February 6, 2010 at 10:30 pm
    You can capture HDV to ProRes. Here’s an excellent tutorial by Chris Poisson which explains the workflow.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Rafael Amador
    February 7, 2010 at 2:14 am
    ..then open a DV50 sequence and edit on it.
    Careful about the field order.
    Rafael.
    http://www.nagavideo.com
  • Paul Witcher
    February 7, 2010 at 10:30 am
    Hi John, HD I’m fine with, it’s the SD stuff I’m not sure about i.e what is the best way to capture it? and can I use ProRes?
    Paul
  • John Fishback
    February 7, 2010 at 5:28 pm
    With the exception of capturing HDV over FW, I’ve never captured SD that way. I’ve always used a deck and capture card. I’m sure it’s similar to the HDV workflow, just changing it to DV. I don’t know if DV can be captured to ProRes over FW. Rafael will probably know. You can drop the DV into a DV50 timeline & edit as Rafael mentioned above. That will also treat graphics and text much better than a DV timeline. Rafael, please correct me if I’m wrong.
    John
  • Rafael Amador
    February 8, 2010 at 1:26 am
    Sure, you can capture the DV as Prores too.
    But I wouldn’t capture the DV, neither the HDV as Prores.
    I would edit native in a DV sequence and shift to Prores before exporting.
    rafael
  • Gary Ellison
    April 9, 2010 at 8:41 am
    Hi Rafael,
    What do you mean by shift to prores? Do you mean move your dv-pal timeline to a pro-res one?
    Cheers
