Activity › Forums › Adobe Premiere Pro › SD PROJECT now needs to be HDV
  • SD PROJECT now needs to be HDV
    Posted by John Chin on February 16, 2009 at 8:17 pm
    hi all first post [and last hopefully]
    I captured and completed a full edit of a project in SD thinking that no blu ray delivery was needed [if i know blu ray is needed i capture and edit in HDV and simply export the appropriate filesi.e. down rez’d sd dvd]. I now find out that there is indeed a blu ray disc needed. i am wanting to recapture the project in HDV and export for encore blu ray files. but i can’t figure out how to do it.
    from what i understand, the project itself is regular dv and there is no way to change the resolution of the timeline so even if i delete the source files there is no way to recapture hdv in this project [please prove me wrong].
    is there a way to export the timeline or a edl so i don’t have to re edit the entire program again?
    Charles Campbell replied 17 years, 6 months ago 3 Members · 3 Replies
  • Jake Williams
    February 17, 2009 at 2:03 pm
    What version of Premiere? If it is Cs3 then you can create a new hdv project and import the original project into the hdv project. You can cut and paste what is in the SD timeline onto the new HDV timeline offline the media, capture HDV from tape and everything should be reconnected.
    Jake Williams
  • John Chin
    February 17, 2009 at 6:29 pm
    yes cs3. i will try what you say. i hope it works
  • Charles Campbell
    March 14, 2009 at 4:30 am
    I’ve run into the same problem. However I need to recapture all of my footage in HDV that was originally captured in SD. Can this be done with Premiere Pro CS3? I have imported my old SD project into my new HDV project and all of the SD AVI files are offline – can I somehow recapture them all as HDV (MPEG2) format?
