Activity Forums Sony Cameras SD progressive copies
  • SD progressive copies
    Posted by Stephen Bale on February 18, 2008 at 3:53 pm
    Maybe i’m missing something. When I try making progressive SD files from HDCAM EX (1080.25p in FCP) they always end up being interlaced. I always tick the Progressive box in Compressor for SD output.
    Mick Haensler replied 18 years, 7 months ago 5 Members · 5 Replies
  • Craig Seeman
    February 18, 2008 at 4:58 pm
    EX1 HD to SD in FCP
    Excellent article explaining how this is done. I hope the COW doesn’t mind my pointing to it since I’d rather do that and make sure the author gets credit that paraphrasing myself.
  • Stephen Bale
    February 18, 2008 at 7:19 pm
    Thanks Craig, that work flow makes an amazing difference to the picture quality. I’m still puzzled though. When I check to see if the SD file is still a ProgScan copy I find it has changed to interlaced. This also happend when using FCP compressor. I’ve repeated this conversion countless times and about ready to admit defeat….. for tonight at least.
  • Ryan Early
    February 19, 2008 at 10:10 am
    How good is the xdcamex picture quality on an sd dvd with that process ? does it look better than material originating on sd ? My experience using hdv downconverted to sd dvd was that it looked much worse than stuff shot on standard def.
  • Don Greening
    February 19, 2008 at 2:18 pm
    [ryan early] “How good is the xdcamex picture quality on an sd dvd with that process ?”
    Provided the down-convert is done properly it looks better than SD. That’s been my experience.
    – Don
  • Mick Haensler
    February 20, 2008 at 1:45 am
    Has anyone tried this process with HDV footage? Sometime in the next few months I’m gonna start editing a doc that was shot in HDV. I usually downconvert from the camera and just edit in SD, but for this one I want to keep it in HDV or some other HD codec.
    MIck Haensler
    Higher Ground Media
