Activity Forums Blackmagic Design SD output to Sony CRT with Decklink HD Pro (single channel) problems
  • SD output to Sony CRT with Decklink HD Pro (single channel) problems
    Posted by John Sackey on September 20, 2006 at 11:20 am
    Hi all.
    I’ve had a look and haven’t really found anyone with this problem so hopefully I’m not covering old ground.
    We have a G5 with Decklink HD Pro Single channel on board. I have managed to get all of the preferences working so that we can see the output from FCP on a Sony CRT via RGB and it looks great. The problem is that when playing either the sequence or a clip the monitor output holds the last frame as a still and when you hit stop changes to the frame you stop on i.e. the picture on the monitor does not move during playback. If I turn off mirror on desktop nothing changes.
    Any suggestions?
    Thanks in advance.
    John
    al*********@*ac.com
    Wawaii replied 19 years, 7 months ago 3 Members · 3 Replies
  • Olivier Jean
    September 20, 2006 at 11:50 am
    make sure under the view menu, that the external monitor is
    switch to all frames or apple F12(short cut).
    That will be the first thing i would check…
    [John Sackey] “If I turn off mirror on desktop nothing changes.”
    What do you mean by mirror on desktop?
    Regards
    Olivier Jean
    Video Sales Consultant
    Apple Certified Trainer Final Cut Pro 5
    Powermedia Systems
    Sydney Australia
  • John Sackey
    September 20, 2006 at 12:37 pm
    It is set to all frames. Sorry, forgot to mention that.
    Mirror on desktop is in A/V settings. It means that you have playback in the viewer as well as on your output.
    John
  • Wawaii
    September 29, 2006 at 5:05 pm
    John,
    I have the same setup you have. I had that problem once with the Sony when I tried to play back 24fps from the timeline.
    Juan
