Activity Forums Adobe Encore DVD SD Material on Blu-ray
  • SD Material on Blu-ray
    Posted by Andrew Golden on July 31, 2009 at 1:19 pm
    Has anyone had any experience incorporating SD material on a Blu-ray disk. I know the format allows for it but I haven’t been able to find much on the process for actually putting SD content on a Blu-ray without upconverting the SD to HD first and taking up more space and bandwidth than the SD material needs.
    Thanks for the advise.
    Andrew
    Andrew S. Golden
    President
    Illusion Media LLC
    Jon Geddes replied 17 years, 1 month ago 3 Members · 2 Replies
  • Joe Bowden
    July 31, 2009 at 7:13 pm
    Blu-ray supports all SD video content except 23.976 fps. Simply import the asset, put it into its own timeline and you should be all set.
  • Jon Geddes
    July 31, 2009 at 8:03 pm
    Yes, I have had experience mixing SD and HD content on a Blu-ray disc authored in Encore. SD content was already transcoded to MPEG2 DVD, and HD content was transcoded to h264. Encore will not re-transcode SD mpeg2 files. As Joe mentioned, make sure the SD content is placed in it’s own timeline.
    Jon Geddes
    http://www.precomposed.com
