Activity › Forums › Apple Final Cut Pro Legacy › SD & HD mastering
  • SD & HD mastering
    Posted by Paul Belanger on January 9, 2006 at 6:01 am
    My client decides they not ony want an HD master but also an SD master.
    Simple enough, I have the Kona 2 card which will let me do that.
    What do I need to do about my graphics?
    Do people make lower third graphics in HD
    where it has good clearence for the SD screen?
    I don’t want to chop off my graphics.
    This is going to be hard to explain to the client’s graphic designer who giving me stuff in SD anyway. I’ve been saying to give me HD graphics.
    Also picture
    After working with the clients HD footage for a couple weeks they give me some SD footage to use in the project.
    What to do with this? I don’t want to stretch the picture.
    How will this SD footage fit in my HD sequence?
    Walter Biscardi replied 20 years, 8 months ago 2 Members · 1 Reply
  • Walter Biscardi
    January 9, 2006 at 12:40 pm
    [Paul Belanger] “Do people make lower third graphics in HD
    where it has good clearence for the SD screen?”
    Depends on the client and application. Some clients want all their titles protected for 4:3. The shows I work on we do two completely different passes as we put the titles right on the edge of safe title in both the SD and HD shows. I prefer this so you can get the graphics “out of the way”.
    [Paul Belanger] “This is going to be hard to explain to the client’s graphic designer who giving me stuff in SD anyway. I’ve been saying to give me HD graphics.”
    They just need to go back and change their image size to whatever frame size you’re working in. Just have them give you two sets of graphics, one for SD frame and one for HD frame. They need to know that the font size is generally larger in HD graphics than SD graphics because the frame size is so large to begin with. Not tremendously larger, but we usually make them a few point sizes larger.
    [Paul Belanger] “What to do with this? I don’t want to stretch the picture.”
    You can set how the Kona 2 upconverts the footage so try some tests. I usually do let the footage stretch out because it doesn’t look overly bad in 1280×720. If I do leave it in 4:3 aspect, then I either build a graphic around it or run a moving background behind it to fill the rest of the screen.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
