Activity Forums Apple Final Cut Pro Legacy SD Footage Suddenly Pixelated
  • SD Footage Suddenly Pixelated
    Posted by Levi Peretic on July 1, 2025 at 10:36 am
    I’ve been using Final Cut 7 for years to transfer, edit and export VHS footage. I use it nearly daily. Suddenly, without any warning, my exported footage is pixelated.
    Thoughts lots of trial and error I’ve discovered if I make zero edits to the footage, it exports fine, but it’s once I edit it the whole thing goes to hell.
    Another thing I’ve noticed is when I make a freeze frame, it appears pixelated in the viewer window, but when I drag it into the timeline, the image becomes clear. I often use freeze frames to repair glitches from the tape transfer. I cover them up using portions of the previous frame. Sometimes an export will appear to be clear, but anytime it hits a repaired frame using freeze frames, it becomes blurry.
    Another weird thing it’s doing is when I export using QuickTime Conversion, the image of the canvas window becomes pixelated.
    The footage I’m editing is usually
    720×480, DV/DVCPro-NTSC
    I normally export at
    720×480, AppleProRes LT
    I’m at a loss. I even uninstalled and reinstalled FCP with no luck. It’s probably a shot in the dark, but hopefully someone can help.
    Mads Nybo jørgensen replied 1 year, 2 months ago 2 Members · 1 Reply
    July 5, 2025 at 12:05 pm
    Hey Levi,
    As you say, you have been doing this daily with no problems. So there is every chance that the following suggestions might not be relevant.
    First port of call, just to check that settings have not been reset or altered:
    What are the settings for your timeline?
    If it is above the “NTSC frame”, like HD or higher, then it could go pixelated.
    The other part I would suggest that you check up on is your Hard-Drive and/or SSD.
    “Pixelated” could be an early warning signal that you drive is end-of life, if you have been using that too for a very long time. Or, maybe it just has some bad sectors.
    Should add to the above that QuickTime on PC and Mac is no longer supported.
    https://discussions.apple.com/thread/254271934?sortBy=rank
    ProRes is, but maybe MP4 is better for you in quality and storage space required.
    Hope that you find the issue with the pixelated footage.
